I would like the ability to link a WTPart to another WTPart such that structure updates in the first will build in the second.
The use case would be a "same, but different" assembly design where the structure should match an existing assembly, with only a few changes. The first WTPart could be CAD driven, or directly updated. When it is iterated, any structure changes should then build into the second WTPart.
The second WTPart would maintain it's modifications (part adds or removes). This would work exactly the same way a WTPart can have manual edits even when it is CAD driven.
