CAD Assembly Structure tab default to Merge Uses
When you look at the Structure tab for a Creo CAD assembly in Windchill, the table view is set to Separate Uses by default. Every single instance of every component, down to each fastener, appears on its own line in the table view.
By clicking Display > Merge Uses in the Viewing group, components will be grouped together on the same line in the table view. However, there is no way to set this as a default.
When looking at the top level assembly, especially for complicated models, it is useful to have Merge Uses set as the default. However, there is no way to do this. There is an SPR (2155064) from 2012, but it is set to "No plans to fix" (which makes no sense).
There should be a preference to allow Merge Uses to be the default instead of Separate Uses.
10 Comments
TomU
23-Emerald II
David, don't forget to vote up your own idea!
dmartin
11-Garnet
Thanks, Tom. I always forget that you don't automatically get an up vote on your own idea. (That also makes no sense.)
PTCModerator
Emeritus
HamsterNL
We could use this functionality as well!
+1 from us too
jwagh
VOTED!
ryanwolff90
2-Guest
This functionality would be extremely useful. Even if it was just made a preference that a user can change.
JoergEhrenstein
11-Garnet
Thumbs up from our customers, too.
We woulds like a preference and the possibilty to save it individually direct in the structure views.
LPE_EF
Commenting for visibility, I'd love this feature
JoshuaHouser
Is this really based on a 9 year old SPR??
TomU
23-Emerald II
@JoshuaHouser,
Yes.
