The Windchill Customer Experience Management (CEM) module has a number of tables within the module that are restrictive as far as the columns that can be added or removed. This is because they are not implemented as configurable tables. I would like the capability to configure the columns/attributes presented in the UI by creating custom table views via the table view manager for such tables. Examples are Related Persons and Related Products tables in the Complaint Intake wizard, tables in the Complaint Management tab etc.
This issue extends farther than the UI's mentioned as examples above. Across the board in CEM, the standard Windchill design of using configurable table views should be implemented to allow for easily configurable UI's.
