When I set “TESTXYZ” with SolidWorks in Naming Parameter(Option->Upload Operation->Upload) (pic_1 )and add Property in Solidworks “TESTXYZ”(pic_2), the result is correct(pic_3).
But if I add a space just like “TEST XYZ”(pic_4), the result is wrong(pic_5).
