We have auto number configured for CAD Documents. When we create a new CAD Document, we see the tag <auto generated number> and the number is not generated until "OK" is clicked.
We want to achieve similar functionality for the "Save As" functionality. But right now it generates the number and then shows in the dialog.
Problem with this is the sequence number gets consumed unnecessarily if the user cancels the operation.
Hence we want to show <auto generated number> instead of actual number for Save As as is the case for New
