1. Right now if we want to replace any part(Child) in spreadsheet then available option is to use DELETE keyword to delete the existing part(child) from the part structure and then use ADD keyword to add new part (child)
2. Can we have a new keyword along with Delete and Add , i.e REPLACE keyword to simply replace the part from Spreadsheet?
3. This feature of “Export-Import Spreadsheet” will be highly helpful for bulk creation of bill of material in Windchill thru excel utility.
4. This action is available in UI , it should be available in Spreadsheet also .
