Capability to Create Multiple Part Instances
It would be great to have the ability to create multiple Part Instances from the Actions menu of a Serialized Part.  The current Workflow is clunky if creating multiple instances with same Configuration as would potentially be the case when ordering components, especially given that you "land on" the newly created Part instance and need to go back to the base part to create the next instance.
Even a Create Multiple New Action from the Folder Contents Table similar to Parts and Documents would work.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
