Capability to configure the default structure filter
In the Product Structure Browser it is possible save user specific filters and system-wide filters that can be shared with all users. If a user applies a filter this is stored for some time for a specific structure, but it will not be kept when opening another structure. For some use-cases it is beneficial to always start with specific filter other than the default filter.
At our Windchill Installation we use WTPart View Versions to grant specific user groups an alternate "reduced" view to WTParts. This is how we represent an internal customer-supplier relationship. The internal supplier is maintaining the Design View, while the customer is using the "Reduced View" in their structures. This reduced view does not have a BOM, but has for instance a simplified representation attached or specific documents. To see this reduced view the user has to set a specific filter to not see the WTPartMaster in the structure. If a default  filter that lists first the Design View and than the downstream Reduced View could be configured, this customer-supplier interaction would be more seamless.
7 Comments
BjoernRueegg
Jeffrey Zemsky‌ do you know if this idea is being released in 11.0M030?
dritter-3
Info from PTC TSAM Meeting: It´s planned for Windchill 11 M040
PTCModerator
Emeritus
Status changed to: Current Functionality
JeffZemsky
Windchill 11.1 will support a user selecting a Saved Filter to be used as their Default Filter for PSB.  Note the user should pick a filter that makes sense for a default - that is if they pick a filter that has a specific baseline it might be of no use for other BOMs.
Jaime_Lee
Community Manager
Status changed to: Delivered
Release: 11.1
dritter-3
Thank you very much for the implementation in WC 11.1
Looks fine.
Mark08
3-Visitor
This is a very nice feature, that has been added!
Can the 'Set as Default' also be added to the CAD Document Structure? It would be very nice to have it!
