Capability to keep WTPart and EPMDocument (owner) on the same Number
Usually the WTPart and the linked EPMDocument (owner) has the same Name and Number.
Due create there is no issue (for example EPMDocument = autonumber, WTPart = manually number => Auto-Associate => Name and Number is the same for WTPart and EPMDocument)
But not so on "Rename" and "Save as".
It would be very helpful to have a (optional) synchronization-service for that.
6 Comments
BjoernRueegg
Also for drawings! In the Workspace you have not oportunity to name the drawing with the same number as the model and part. e.g.
Drawing: 4711.DRW
Model: 4711.PRT
WTPart: 4711
Unfortunately the PDMLink doesn't know that the drawing has the same number as the model. So it just pulls a new number if you call the save as and rename command.
GregoryPERASSO
good idea, even if difficult to implement, as a CAD part can have several Drawings ...
BjoernRueegg
There are several possibilites to implement also some drawings.
Just add a suffix e.g. "_1" to the number.
Drawing 1: 4711_1.DRW
Drawing 2: 4711_2.DRW
Model: 4711.PRT
WTPart: 4711
The good thing is to find everything related to this number.
SteveShaw
In Windchill 11.0 F000 improvements have been made to help keep the WTPart and CAD document in sync during Create New (Part or Document) as well as in the Rename UI.  There are plans to extend support to Save As in a future release.
TomU
PTCModerator
Emeritus
Status changed to: Current Functionality
