Usually the WTPart and the linked EPMDocument (owner) has the same Name and Number.
Due create there is no issue (for example EPMDocument = autonumber, WTPart = manually number => Auto-Associate => Name and Number is the same for WTPart and EPMDocument)
But not so on "Rename" and "Save as".
It would be very helpful to have a (optional) synchronization-service for that.
