Carriage Returns in Memo field
In Windchill Reliability module, the memo fields are really usefull, however the only means of adding a carriage/charactor return is to write something in word/notepad copy it out of the field, modify it and paste it back in to the memo field.  Could a means of enabling this either through ctrl+rtn or similar, or through the alt+code route?
3 Comments
ptc-6160238
1-Newbie
This Idea cannot be voted up enough!
ptc-2749313
1-Newbie
When you create a form and include the memo field on the form, edit the field's properties so that they are "multiline".  to do this, select the field and then right mouse button click.  select Properties and then pick the Styles page.  on this page you can configure the Styles to include Multiline as well as other options.
PTCModerator
Emeritus
Status changed to: Archived
