I'm currently and intensively using cascade attributes rules to guide my people into new WtPart attributes population. But I've in my database a lot of legacy WtParts whose attributes do not fit anymore the rules we set for new ones. In this scenario it is not possible to modify any attributes of this legacy parts, no matter if you make it trough edit mask or by importing an excel file. Cascading rules will block it.
The only way I have to be able to make a modification of these legacy WtParts is a time-consuming workaround:
1) make a loto of printscreen or document in detail the tree of cascading rules (in my case, round 30 rules)
2) delete all rules that are blocking the validation of the edit form or of the excel file (in my case, almost all)
3) make the modification
4) re-insert newly all the rules copying them form the screenshot.
Not comfortable at all.
I suggest to place a toggle button to manage a flag into the cascading rule tree in WtPart Type and Attributes management interface: Rules ON-OFF.
By toggling it we can easily deactivate rules, make editing of these legacy WTParts and then toggle them again ON.
A more advanced feature can be the toggle flag posed on each rule, shown by right clicking the mouse on the rule itself.
