The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Change Notice sequence numbering
Change Notice using sequence numbering from 1-9 which is confusing when sorting via sequence number.
Suggestion: Use sequence numbers 01-09 to keep logic numbering.
4 Comments
BenLoosli
23-Emerald II
Numerous other product ideas open to change the sequencing to a true numerical sort.
JørnAHansen
2-Guest
‌I dont see any duplicate ideas when looking at Windchill  ideas filtered for "sequence"
JørnAHansen
2-Guest
‌AFAIK the suggestion
does not work (tried on 10.2 M030) as the leading 0's are thrown away on save.
Best workaround we have use so far in our templates is to start sequence numbers from 10 - and keep them below 99 😉
olivierlp
Community Manager
Status changed to: Archived
