Add affected objects to all change tasks for a change notice instead of just the initial or "default" change task. Currently when a change task gets created via a change notice only this initial change task will have the affected objects list populated. Any additional change tasks created in the work flow show none. You can manually add them but this causes duplicates to be added to the change notices affected objects (this is addressed in another product idea related to this topic).
