Change Task collection window does not have collection of Part Instances. The Change Management system does not incorporate Part Instances.
A change to the base part can affect part instances. Seems logical that instances are related objects that should be able to be easily collect for change.
Reference: https://www.ptc.com/appserver/cs/view/case.jsp?n=12638162
