Change display of real numbers
For the moment it is not possible to change the display of real number ( now up to 14 significant digits) (CS36590)
It would be better if you could change this to avoid for example: 14.0000000000
3 Comments
OliverDroop
Unexplainable why a good GPD Solution Graham BirchBirch‌ requires still customization for such a tiny detail which would be very easy to solve.
Interesting is this here
On the other hand, LoadFromFile *.xml files and csv files have the number of significant digits supplied with the load for every real figure:
csv: csvvalue2 https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS232145
xml: myValue|precision https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS40610
PTCModerator
Emeritus
Status changed to: Under Consideration
SteveShaw
Status changed to: No Plans to Implement
There are no plans in the near future to change the behavior of real number display in particular as it relates to real attributes passed from CAD.  However, in some cases the wt.properties setting  com.ptc.core.meta.common.NumericToolkit.IGNORE_PRECISION_ENABLED=true has shown to address this display concern.  I would suggest trying.
