The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Change how user information is defined in Windchill
So this is a small annoyance and probably difficult to change in the system.
It just seems to differ from current standard practices.
Name = User ID/Login ID/...
Full Name = First and Last Name
Last Name = Last Name
I know you can change the labels, and we have on Name, but the Full Name/Last Name is kind of annoying and differs from most form filling practices I've seen.
Typically the name is split into First/Middle/Last and then the Full Name is a calculated field from those. From there you can decide through system preferences to show "First Last", "First Middle Initial Last", "Last, First"... etc.
4 Comments
slapha
TomU
You can customize participant administration to add additional attributes (first name, middle name, citizenship, etc.)
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS162357
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=WCCG_Serv_LDAPUerInfoPage_Intro&action=show
You can also change what ldap attribute gets mapped to the full name field.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS223665
STEVEG
This is really annoying.  PDMLink had separate First Name, Last Name in 9.x.  I don't know why they changed it.
olivierlp
Community Manager
Status changed to: Archived
