Change notice - add change tasks with multiple choice
At the moment we create implementation plan templates for various change scenarios and need to delete the tasks which are not needed in this case.
We imagine a solution with a multiple choice feature.
The creator of the change notice can pick all tasks from a library/template who are need for this case.
4 Comments
JeffZemsky
Status changed to: Duplicate
This is a duplicate of the following idea.  Closing it as duplicate.  Please vote for the other?
Multiple deletion of Change Tasks - Change Notice
Avalo
Yes your suggested change idea is also important. But this change idea goes futher than just a better delete option.
The issue is, if you have too many tasks and you need a lot of combinations of these tasks then the amount of templates that need to be created would multiply by a huge amount.
I imagine a button "Pick predefined tasks"  above the task overview in an implementation plan which opens a seperate window. In this window you can collect the predefined task (select, select all, deselect,...) that you need and with one click "add" them to the implementation plan.
lhoogeveen
@JeffZemsky This is not a duplicate of the other Windchill idea you linked to. This idea is making it easier to add tasks from a multiple choice menu (probably from the first page of the create Change Notice page) or pick from a predefined list of tasks. The other idea you had listed was for deleting multiple tasks at once.
Avalo
Can someone please reset the status?
