Within the Process Status block for Change Tasks, and other change objects, the Latest Action Performed shows if a work item task is open, approved, or accepted.
The only problem, Approved is a check mark. Accepted is a check mark in a green circle.
About 1-2 people a week sees the "Accepted" check mark and think it means Approved.
Process Status - Latest Action Performed Icons
My suggestion is to change the Accepted icon to be different than the Approved icon for improved clarity.
