Change the Checkboxes in the "Routing/Process History" Table for Change Management Objects
When multiple Processes (including Proxy Processes) are run on a single object, they appear in the "Routing/Process History" table as shown below.
Each Process has a checkbox in the first column.  However, the information only displays for one checkbox at a time, and only if that checkbox is selected when no other boxes are checked.  To clarify - if I wanted to switch process displays in the image below, I would first have to uncheck the top box and then check another row's entry.  If I select another row and then deselect the top box, the data display will not properly refresh.
This is a bit clumsy and unintuitive.  If only one selection can be displayed at a time, radio buttons should be used, not checkboxes.  Ideally, multiple selections could be made and the information would display task history from the union of the two processes.
3 Comments
Newbie
If two check boxes was selected and then only one, also the process status is not updated. It is necessary to recheck in order to display good information.
It should be more intuitive because we think that it's a bug of display.
Several information should be displayed according check boxes selected.
Community Manager
Status changed to: Archived
Moonstone
This was implemented, they are now radio buttons. Not sure when it was applied, but in 11.1 M020 CPS 5 they are now radio buttons. Noticed it after our upgrade.
