Check-in comment
Check-in comment
Hello. My suggestion is that the ability to add check in comments be implemented under actions menue. Very often you have to do some workarounds for a check in comment. When you miss one on CAD, you have to undergo the time-consuming task of adding it to the workspace, opening it, making a meaningless change and checking it in again.
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @B_Steiner for publishing your idea and welcome to the Community. However, we need more information as specified in the form you saw in the submission process. (questions below). You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Here are a few examples of well documented ideas:
Merge occurrences in Compare to Part Structure too... - PTC Community
Subcontract enhancement - Ability to define contex... - PTC Community
Windchill preference values on user & container le... - PTC Community
Windchill alias attributes should be able to map w... - PTC Community
MPMLink - Ability to duplicate (save as) a Process... - PTC Community
Easy way to view Service Effectivity that's been a... - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
JenniferPierron
Status changed to: New Idea
Hello @B_Steiner
Please see my post about a new default check in comment preference for CAD Documents on this idea: https://community.ptc.com/t5/Windchill-Ideas/check-in-comments/idi-p/466782
I hope it will help to provide version history even if the CAD user did not or could not provide a check in comment.
Jennifer
