Windchill Clientinspector enhanchement Ideas:
- <preCompare> conditions are not up to date. (example: IsOldOs only checks up until Windows 7, and the isIE checks end with 9)
- multiple precompare conditions should be possible (Example: IsWin8 and isIE10)
- adding user-defined checks should be possible (Example: Ping Windchill Server response time)
- adding user-defined precompare conditions should be possible (Example: "Ping Windchill Server response time" > 50)
- Use Excel Tables in the result template
- Compatibility check should be included
- Recommandations should be reevaluated
