Client Inspector enhancements
Windchill Clientinspector enhanchement Ideas:
  • <preCompare> conditions are not up to date. (example: IsOldOs only checks up until Windows 7, and the isIE checks end with 9)
  • multiple precompare conditions should be possible (Example: IsWin8 and isIE10)
  • adding user-defined checks should be possible (Example: Ping Windchill Server response time)
  • adding user-defined precompare conditions should be possible (Example: "Ping Windchill Server response time" > 50)
  • Use Excel Tables in the result template
  • Compatibility check should be included
  • Recommandations should be reevaluated
2 Comments
STEVEG
I just tried this and it seems it does not get the OpenGL version.  This MUST be added since Creo 3 requires OpenGL 4.0 and Creo 4 requires OpenGL 4.3.  That means we have to have a separate program that records the version.
olivierlp
Community Manager
Status changed to: Archived
