When the Workgroup Manager Collector is used to either Exclude/Reuse/Replace/etc... objects within the table content for the action selected, there is currently no way for a user to set those objects back to their initial status. As an example, during a Save As, If I select an object in the list and set it to be reused, I cannot have it set back to be copied without either me resetting the entire table or canceling the action and redoing it all over again.
