The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Collector dependency to update object list
Switching the Dependents value from All or Required to None does not remove the associated objects that were collected from the dependents that are removed.
See attached videos to see the current functionality.
PTC Technical Support has created the following article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS108961&source=Case%20Viewer
Example enhanced workflow:
    1. A Part with structure is chosen for Revise
    2. In the collector Dependents is set to All and entire Part structure is collected
    3. All Parts displayed are selected and user collects associated EPMDocuments
    4. User then switches Dependents to None
    5. All Parts but the initially selected Part is removed and the associated EPMDocuments remain in the collector
1 Comment
olivierlp
Community Manager
Status changed to: Archived
