Column width in the workspace
The admin shoud be able to define the column width in the workspace.
In the commonspace this is possible since Windchill PDMLink 10.1 - but in the Workspace the value for <width> is always "0" and a change of the value dosn't have any influence.
18 Comments
ThomasBittner
Yes that would be very helpful
mstevens-2
2-Guest
For Creo in general, users would benefit greatly if windows that require resizing or columns pulled wider to see all content could have those user changes saved in the configuration. It is so frustrating to do this over and over every single time I open them. This would truly be a time-saver and be one less headache.
STEVEG
I don't see where you can set the width of each column in commonspace.  It is possible to set the Freeze column but not the width of each that I can see.  Please tell me I am missing that part.
DanielKremers
3-Visitor
That's easy:
- Define your Table-View
- Activate defined Table-View
- Move column-width as needed
- Click on Disc-Icon byside view to save the view
Now the column-width has been saved.
RandyJones
Daniel Kremers wrote:
That's easy:
What "Disc-Icon" are you referring to? I do not see a "Disc-Icon" anywhere (Windchill 11.0 F000). Can you provide a screenshot?
STEVEG
Ah.  I think he means this.
STEVEG
And it does in fact save the column width.
Thank you Daniel Kremers
RandyJones
Ah I see....
I was looking for this in a Workspace and it is not available there.
STEVEG
And it's not available in other places in commonspace.
DanielKremers
3-Visitor
Exactly - and this is the reason fpr my request 😉
That is the difference between the "old" UIs (like Workspace) and the "new" UIs (like Commonspace-Table-Views).
It is also possible when the "Disc-Icon" is not available - but the "Save view"-command in Drop-Down-Menu.
And there is a second method:
- You can export the view(s)
- Edit the xml-file: <width>32</width> (enter the required value)
- save and zip
- import
Regards Daniel
JenniferPierron
Hi Randy.
We are in the process of trying to add this to a Windchill 11.0 MOR.
Here is a preview:
Jennifer
RandyJones
Jennifer Pierron wrote:
Hi Randy.
Great. I will be looking forward to this MOR.
SteveShaw
Saving column widths for the workspace listing is currently planned for 11.0 M020.
JenniferPierron
Yes!
JenniferPierron
For 11.0 M020, we only added to the WS; but let me know what other UIs you are looking for.
I see FT report above.
Jennifer
SteveShaw
11.0 M020 is now available and includes saving of workspace column widths.
PTCModerator
Emeritus
Status changed to: Current Functionality
Jaime_Lee
Community Manager
Status changed to: Delivered
Release:  11.0 M020
