Compare tool for comparing Process plan revisions
PTC is doing good with MPMLink product. Every body started liking it much..
As I am working on MPMLink from past 5 years.. Process plan structure page improved very well in terms of actions against Process plan and its objects.
Please add Compare tool for comparing Process plan revisions / iterations in history table. This will help debugging on what is changed with pervious version.
Better to give a report by comparing all its structure objects.
Shyam.
[Note from Community Management: We have merged 3 identical ideas into the newest one (above). The process intends merges the unique votes and sort all comments chronologically, regardless of what idea they are coming from. We hope that the conversation remains coherent. July 21, 2022]
20 Comments
HelesicPetr
Our customers ask for a compare function of MPMLink objects.
For ProcessPlans and Operations this function is not part of a WindchillMPMLink.
I would like to add an Idea to implement same function for ProcessPlans and Operations as exists for wt.part structure.
The function could be very useful for cooperation work if one user does some changes on operations then others should be able to see the diference
between released Opeartions or ProcessPlan and current inwork objects.
JiriKrenek
1-Newbie
Very good idea
aalves-2
6-Contributor
Very good idea ! It will help to building the BoI (Bill of information)
GregoryPERASSO
Being able to use the Windchill 10 compare tool (HTML UI like the Part to Part comparator or the CAD to Part comparator) , for comparing 2 Process Plan structures.
Formely the "PP to PP comparator".
To easily compare Structures,attributes and related objects of a PP, of 2 MPM Process Plan structures:
- 2 differents versions/configurations of the same Process Plan(ie sameProcess Plan Master)
- 2 differents Process Plan (ie different Process Plan Master)
related objects to compare (Docs , CADDocs, Ressources, Tooling, consumed and related WTpart) should be selectable as in Part to part comparator
With Filter configspec capabilities (like the part to part comparator) for comparing:
- LifeCycle state Filter
-Baseline
-promotion Request ...
-Effectivities
and other filters applicable to Process Plan
ChrisPLM
8-Gravel
If MPMLink is to be adopted by users it must provided basic functionalities which can be found in ERP system,
This was a topic in a discussion not that long ago.
I fully support your idea Greg.
ChrisPLM
8-Gravel
GregoryPERASSO
Sorry ... missed it even if I voted for it ....
ChrisPLM
8-Gravel
no problem,  can the vote be merged ?
I think this is a really important future and hope PTC is looking at what ERP system deliver in MPM and get more inspiration to finally provide MPMLink that surpasses ERP capabilities
GregoryPERASSO
yes of course. you can merge
just hope that MPM team will have budget for this kind of mandatory new features ...
where it seems to be difficult to have budget "just to move" from applet to HTML UI with iso functionalities ....
ChrisPLM
8-Gravel
Hello Gregory.
shame you won t be able to make. Good luck with your milestone.
Is there a possibility to join your discussion with PTC about process plan or is it just between your company and PTC ?
Best regards
GregoryPERASSO
Chris
Today it's only between our company and PTC
I know that they do this kind of meetings with other customers
Anyway I can ask to PTC if possible
GregoryPERASSO
Also add the ability to compare Itérations in the Version History table of ProcessPlan and Operation, as any other iterable Windchill object
result
ChrisPLM
8-Gravel
Always on top of things Greg.
Very good suggestion.
GregoryPERASSO
this one was easy to achieve by customization, has the compare history action Framework exists for Iterable objects ...
our developper was able to do that in 2 days by adding some entries in XML files ....
but should be OOTB ....
ChrisPLM
8-Gravel
I could not agree more. We want OOTB functionality
Ideally, I want to do all my MPM in Windchill and simply push the released data into ERP for transaction activities.
Keep ERP for transactions and all collaborative and iterative work in Windchill. It does require a bi directional bridge with ERP but that would be so efficient.
Unfortunately, MPMLink capabilities (even version 11) are far to compete with best in breed ERP.....
GregoryPERASSO
You're right 🙂
not "should be" .... but "Have to be"
ChrisPLM
8-Gravel
don't forget to like . I have not had any points for a while  as I was quite inactive recently...
SergeLABORDE
I have the request : we need to compare 2 versions of process plan or 2 versions of operations. Very helpfull to approve a modification. This is a big lack today.
qntran
How did you able to get the option Compare for Process Plan? It a custo? I dont have that option OOTB in 10.2.
thanks
olivierlp
Community Manager
