Complete Task button - reposition
When you are giving your approval there is a "Complete Task" button that is on the far right side and you usually have to scroll over to see it. Can you change that so you can view it without having to scroll to the side?
Problem:  On all tasks, when signing (?) / granting approval there is a "Complete Task" button that is on the far right side and you usually have to scroll over to see it.
               Suggestion:  Change the layout so you can view the "Complete task" button without sideways-scrolling.
3 Comments
kpritchard
You can create custom Task Form Templates that would allow you to change the position and/or justification of this button so it is doable... needs admin permissions and has global effect rather than being controlled User by User.
You select the Task Form Template for a given workflow assignment in the Workflow Administration utility.
aderoo27
3-Visitor
Although customization is possible, having a usable layout in the first place would help. I would also like to add that it is just not a scrolling to the right that is needed, but scrolling to the bottom as well. Additionally, not having the Approved option preselected would be nice to avoid accidental approval and for the user to make a conscious decision on the vote needed.
olivierlp
Community Manager
Status changed to: Archived
