Current components input process necessitates to fill-in a huge amount of data (including component category, sub-category, Pi-placement, Pi part manufacturing, component caracterictics (voltage ratio, power ratio, temperature rise, package, ....).
Import from excel spreadsheet is very conveninent as it can be used to import and update a huge amount of data at one time.
I am facing an issue : as we are using reliability prediction as a basis for engineering, we have to study many configurations of a given build of material in order to capture which design best fits reliability objectives.
Using built-in article table is nearly useless as mass modification is very limited and as not all fillable fields are available to the user.
Import with an excel spreadsheet could be more convenient but not all article fields are available for import.
If one could :
1- either preferably access to all article fields within import tool.
2- or access all article fields within article table and update them in mass.
So that we could import / update data much faster, it would be greatly appreciated.
