In Pro e there is Name and Common Name values.
Where:
Name maps to PDM Link File Name
Common Name maps to PDM Link Name
In PDM Link there is File Name and Name values.
Where:
File Name is really the same as Name in Pro e
Name is really the same as Common Name in Pro e
Pro E----------------------PDM Link
Name--------------------->FileName
Common Name--------->Name
Why the lack of consistency across the products? Can't ProE/Creo be changed to FileName and Name?
