It would make sense in our processes to have the rename and edit attributes functionality all together. The usual user task is better phrased as 'go assign these legimitate part numbers and descriptions [not the windchill description] to the cad data'. Currently this is acheived by the users changing the name, number, filename via the windchill menus and the description and other parameters via Creo (because the Windchill UI for the same is so bad). You could probably make everyones life easier by simply having a back door upload new identity data function and just using an excel file to re-assign the details on a whole bunch of data at once.
