Containers accessed through the DTI shall be flagged as recently accessed
When using exclusively the Windchill Desktop Integration, if the user accesses a container, this container is not flagged as "Recently Accessed" ( whereas it is taken into account by using the Web interface).
The list of default containers through the Windows Explorer can be modified using a preference in Windchill with following options:
  • Recently Accessed + Favorites : containers shall be accessed through the Web Interface to be flagged as "Recently Accessed" or "Favorites"
  • Recently Accessed : containers shall be accessed through the Web Interface to be flagged as "Recently Accessed"
  • Favorites : containers shall be flagged within the Web Interface as "Favorites"
  • All : lists all containers the user has accessed to; this can results in showing hundreds of containers whereas the user typically uses only a few of them
DTI can be found as a great alternative to SharePoint for non-PLM users; however for users using only the DTI to manage Documents, the behavior can be strange which can lead to a bad user experience. The only possible solution for users which are not introduced to the Web Interface will be to select the "All" option however this will result in a waste of time in order to select the right container (can occur several times a day for each user).
Therefore, the objective of this idea is to implement the same way of working between the Web Interface and the Windchill Desktop Integration.
3 Comments
Vikram_Sinha
This idea has been reviewed and acknowledged as a requirement. A future Backlog has been created against this idea.
STEVEG
20-Turquoise
Maybe change the status of this idea?
PTCModerator
Emeritus
