Currently, when we do a replication between replica and master vault in Windchill PDMLink , it will generate a URL to download the file from Master vault using the http. it always download failed if the network is temporarily down, and when this issue happened, there is also no logs could to trace the download
Could we have resumable transfer function to transfer the file again when it failed due to temporarily network down at the first time ?
