Customers would like to create new dynamic documents in the context of an Information Structure.
They ask for a new action in information structure nodes that allow the creation of a new dynamic document from a template and insert it into the current node.
The use case is to search, rather than browse, for information structure nodes (e.g. by attribute) and, once found, add a new dynamic document to it.
