Trying to create a managed structure view for users so that they can see the dependant 2D CAD drawings as well as the dependant 3D parts.
Seems this is not possible when selecting the top level CAD assembly structure. Only related parts and distribution targets are available to select from the SHOW/HIDE menu.
Most engineers are only looking at the CAD objects, so showing this structure is important.
It helps to determine if we have all the relevant 2D drawings completed before we release a machine.
If you show the structure of a top level wtpart, you can show all the releated CAD docuemnts.
BUT, you need to first select all wtparts in the Structure View, then you can select in the SHOW/HIDE command.
