Create Object Initialization Rules Programmatically
0 Kudos
I want a button on the Object Initialization Rule Administration menu that will create a set of rules for various document types.
The UI customization piece is well documented and the button with actions can be added with a little effort.
Unfortunately, the classes required to create the rules are not exposed via the supported API.
This is a request to expose the classes in the supported API.
wt.rule.TypeBasedRule
wt.rule.RuleHelper
1 Comment
olivierlp
Community Manager
Status changed to: Archived
