The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Create multiple downstream views at once
At Boston Scientific, we have the need to create multiple downstream views at once.
We will use the ‘New Downstream View’ feature, however, this currently allows to create only one downstream view. We are looking for ways of creating multiple downstream views at once
The applet’s UI facilitates initiating the ‘New Downstream View’ from a upstream view. In the wizard that follows, system allows user to select a downstream view. This selection is 1 per upstream view. Hence, the outcome is one downstream view created for a given upstream view. This forces the capability to be repeated by the user multiple times, when they need more than one downstream view created from a given upstream view
3 Comments
rjones
3-Visitor
We have the same need and are working on the customization as well.
lgrant
Greetings, we are looking at the same feature. Our use case is a single upstream (eBOM) version with a downstream view (mBOM) then we have a second downstream form the same upstream version that is a variance (mBOM + Varaince). Additionally we may have stacked changes that have not been incorporated into the upstream view (mBOM + Change + Change).
Do you already use the OOB sub-type for the downstream view?
  • Costing
  • Production
  • Testing
olivierlp
Community Manager
Status changed to: Archived
