Creating links that always point to the latest version of an object in Windchill.
0 Kudos
Background: Links to windchill objects are shared in some documents which are rarely modifies. The Documents in links are updated quite frequently. Need a solution to have the links point to the latest version without having the need to modify them.
The links created should not be for a particular (version.iteration) but for the latest iteration even after it is modified.
PTC Case 16558248 was opened for the same. It worked as per our expectation earlier but some how does not work now.
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @ptc-6744441 for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Here are a few examples of well documented ideas:
Merge occurrences in Compare to Part Structure too... - PTC Community
Subcontract enhancement - Ability to define contex... - PTC Community
Windchill preference values on user & container le... - PTC Community
Windchill alias attributes should be able to map w... - PTC Community
You also referenced a support case, but the Community will not have access to it.
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
ScottMorris
@ptc-6744441 describing the as-is functionality to the desired functionality is always a great way to document an idea. you can also use the standard agile user story method “As a [persona], I [want to], [so that].” if you are not familiar with this method, check out this description from Atlassian.
i totally agree with this idea. it would be awesome for users to have an easier way to create and manage links to objects in Windchill. i would envision something like sharing a Google or Sharepoint document, but the UI would include which configuration of the link you would like to have; latest iteration, latest revision, latest "released", etc.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
