Creation of a full Process Plan baseline including valid filter and loaded BOM.
Today's baseline collector for Process Plan is very cumbersome to get exactly correct content.
Root cause is that Process Plan and BOM are treated as two separate structures and Windchill baseline collector does not easy collect Process Plan context based on filter in Process Plan browser Need a "smart" complete process plan content based on filter added to baseline to really get a "snapshot" of data that was open in Creo View and that are the base for a simulation. Needed to be able to reproduce the very same simulation result a second time.
Suggestion is when opening Structure in Creo View in playback mode a user choice is possible to in the very same moment as opening in Creo View also get a baseline.
Then it is possible to use that baseline to reproduce the very same content for simulation in Creo View over and over again.
