Many customers are very satisfied with the use of 3DAccess as a 3D viewing tool for Creo Elements/Direct Modeling data. 3DAccess is used in manufacturing, purchasing, incoming goods etc.
When changing from Model Manager to Windchill, there is a big gap because 3DAccess does not work with the Workgroup Manager and the generation of ProductView data usually takes months due to the large amount of CAD data.
In addition to Creo View it would be good to have the possibility to load Modeling data with 3DAccess via Workgroup Manager from WIndchill.
