Creo Elements/Direct 3DAccess support for Windchill Workgroup Manager.
Many customers are very satisfied with the use of 3DAccess as a 3D viewing tool for Creo Elements/Direct Modeling data. 3DAccess is used in manufacturing, purchasing, incoming goods etc.
When changing from Model Manager to Windchill, there is a big gap because 3DAccess does not work with the Workgroup Manager and the generation of ProductView data usually takes months due to the large amount of CAD data.
In addition to Creo View it would be good to have the possibility to load Modeling data with 3DAccess via Workgroup Manager from WIndchill.
1 Comment
tbauer-2
7-Bedrock
Numbers from one of our biggest customers:
Number of Parts: 9.000.000
Number of Assemblies: 6.000.000
Estimated duration of visualization creation:
* using EPMDoc-Structure for Assembly visualization: 7 years (using 1 CAD worker)
* using CAD-Structure for Assembly visualization: 10 years (using 1 CAD worker)
3D viewing with 3DAccess is already established throughout the entire company as a process critical to the bottom line. How can you migrate such a company successfully to Windchill, even if you installed 20 Workers?
