Creo Illustrate Workgroup MGR - enable import Creo
Being a bit shocked to find that import Creo models into Creo Illustrate is an option when working "disconnected", but not available when connected to Windchill via the Workgroup Manager I've decided to make a plea to the Product Management Team at PTC.
Idea is simple - make it pssible to import Creo prt/asm models into Creo Illustrate via the Workgroup Manager.
I don't understand how exporting a CAD file from Windchill to disk in order to import helps Customers leverage Windchill.  (relationships, linkages, updates etc.)  (Maybe someone can help me out with the use case that the functionality is built around?)
2 Comments
csu
2-Guest
2-Guest
sehr logische Funktion
PTCModerator
Emeritus
Status changed to: Archived
