Current Behaviour:
The Download Service can create CAD Parameters and fill them with system attribute values from the CAD Document or associated WTPart.
Examples are "PTC_WM_VERSION" or "PTC_MODIFIED_BY".
When using the WGM (for 3rd Party CAD applications), there is a set of parameters that can be configured via the Preference Manager for each CAD Application seperately - except for Creo Parametric.
This means, that for WGM managed CAD Applications, there is a larger set of parameters that can be downloaded to the CAD file.
Proposed behaviour:
It would be very good if all the parameters which can automatically be pushed via WGM to CAD Applications could also be pushed to Creo Parametric via a simple configuration.
This would be extremely helpful for the following parameters:
PTC_WM_PART_NUMBER;
PTC_WM_PART_NAME;
PTC_WM_NAME;
PTC_WM_NUMBER.
Ideally, the full set of parameters listed under the "Workgoup Manager Client / Mapping System Attributes and File Properties" should be provided also for usage in Creo Parametric
