Creo View Adapter should publish Images embedded in Creo Parametric 3D models using View > Images
0 Kudos
When a Creo Parametric Drawing has Images inserted using Layout > Images with config.pro option “save_texture_with_model" set to "yes", those embedded images are correctly published in the Windchill publisher's resulting drawing PVZ’s.
Similarly, for a Creo Parametric 3D model, Images inserted into the model using View > Images with config.pro option “save_texture_with_model" set to "yes", should also be included in the Windchill publisher's resulting model PVZ’s.
4 Comments
BenLoosli
Do you have the publishing machine's config.pro with those options set to yes?
vdegaonkar
Publishing 3D models do support conversion of textures. Do refer article or help topic for more details.
Article:  https://www.ptc.com/en/support/article/CS75925
Help topic: http://support.ptc.com/help/creo/view/r6.0/en/index.html#page/creo_view_mcad_adapters/Config-ProE-Fi...
gleonard3
11-Garnet
We opened a case on this C15295908 and were told specifically that embedded Images in Creo Parametric 3D Models using the technique "View > Images" as described above, was not currently supported for PVZ output.  That being said, the older technique of applying textures and decals using the Appearances Manager IS supported, and we've verified that that does work.  Is our Tech Support Specialist mistaken?
vdegaonkar
my apologies, I have mistaken embedded image with 3D model textures. As tech support clarified it is not supported in creo view output.
