When a Creo Parametric Drawing has Images inserted using Layout > Images with config.pro option “save_texture_with_model" set to "yes", those embedded images are correctly published in the Windchill publisher's resulting drawing PVZ’s.
Similarly, for a Creo Parametric 3D model, Images inserted into the model using View > Images with config.pro option “save_texture_with_model" set to "yes", should also be included in the Windchill publisher's resulting model PVZ’s.
