Critical Patch File Size
I have downloaded Windchill PDMLink R10.2 M030 - Critical Patch 06 file ( 5.6GB), when I try to unzip,  it fails
Command UNZIP in Linux does not work for the file size above 2GB.
Kindly make the file extension as GZIP or TAR which will make System Admins job easier
3 Comments
TomU
23-Emerald II
A quick search on Google turns up plenty of options for unzipping files larger than 2gb in Linux.  Voting no.
BenPerry
For example, we use jar -xf <filename.zip> to unzip the CPS.
SenthilKumarVen
1-Newbie
Thanks Ben
