I have downloaded Windchill PDMLink R10.2 M030 - Critical Patch 06 file ( 5.6GB), when I try to unzip, it fails
Command UNZIP in Linux does not work for the file size above 2GB.
Kindly make the file extension as GZIP or TAR which will make System Admins job easier
