WQS version: 11.0 M010-CPS02
If you wanted to copy any numeric values from Numeric fields from the WQS web interface you wont be able to do so. It appears that this functionality has been disabled only in the web interface. However this functionality works good in desktop client.
No errors as such is seen but the issue is quite easy to reproduce. Neither shortcut (Ctrl+c) nor right mouse click -> copy works!
Can this be rectified please.
Thank you.
Mohammed
