The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Cut Sets Calculation in RBD
0 Kudos
When running RBD with Cut-set calculation checked, if the user input preventive maintenance data, the cut-set results will show "NA", that's because too many inputs will complicate the system. So user has to create two RBD models, one with PM to get regular A% results, one without PM to get Cut-Set Results. Can you change the code for Cut-sets Calculation, so that when RBD runs, the Cut-set will ignore the PM inputs and show the result at the same time with RBD results.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
