Hi
When sharing data from PDMLink to ProjectLink, the data will keep the version it was shared as, even if a update is made in PDMLink. The project user can select to update the out-of-date objects manually (great). But the issue is when you view a structure in the project, it will show latest configuration of all data from PDMLink and not the same versions as in the folder view. This is very confusing for the users and prevent them from use ProjectLink as an isolated area for project data which is a absolute requirement for many customers.
The case has been discussed with PTC TS/R&D and need a resolution asap (see attached documentation).
Best Regards
Per
